Saltar al contenido principal
Dell Studio 1737 Keyboard Replacement
Qué necesitas
  1. Dell Studio 1737 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Dell Studio 1737 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: paso 2, imagen 1 de 1
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
  3. Dell Studio 1737 Keyboard Replacement: paso 3, imagen 1 de 1
    • Remove the 4mm ph1 screw under the battery
  4. Dell Studio 1737 Keyboard Replacement: paso 4, imagen 1 de 3 Dell Studio 1737 Keyboard Replacement: paso 4, imagen 2 de 3 Dell Studio 1737 Keyboard Replacement: paso 4, imagen 3 de 3
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
  5. Dell Studio 1737 Keyboard Replacement: paso 5, imagen 1 de 1
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
  6. Dell Studio 1737 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Studio 1737 Keyboard Replacement: paso 6, imagen 2 de 2
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
  7. Dell Studio 1737 Keyboard Replacement: paso 7, imagen 1 de 2 Dell Studio 1737 Keyboard Replacement: paso 7, imagen 2 de 2
    • Remove the ribbon cable as shown
Conclusión
2 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 694
