Saltar al contenido principal
Dell Optiplex SX280 RAM Replacement
  1. Dell Optiplex SX280 RAM Replacement, Panel Cover: paso 1, imagen 1 de 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 RAM Replacement: paso 2, imagen 1 de 2 Dell Optiplex SX280 RAM Replacement: paso 2, imagen 2 de 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 RAM Replacement: paso 3, imagen 1 de 2 Dell Optiplex SX280 RAM Replacement: paso 3, imagen 2 de 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 RAM Replacement, RAM: paso 4, imagen 1 de 1
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
  5. Dell Optiplex SX280 RAM Replacement: paso 5, imagen 1 de 2 Dell Optiplex SX280 RAM Replacement: paso 5, imagen 2 de 2
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
Conclusión
To reassemble your device, follow these instructions (steps 1-3) in reverse order.
8 personas más completaron esta guía.
Wyatt
Miembro Desde 10/06/10
775 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 22-4, Maness Fall 2010 Miembro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Miembros
26 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 5,469
