Introducción
Introduction
Ram is your laptops temporary memory and can be replaced if damaged or you can upgrade it. This will help run more programs or make the ones you run faster and more efficient.
This Guide Will Teach You
  1. Where the ram is located
  2. How to remove safely
  3. Tools needed to complete the replacement
Partes
No se requieren partes.
Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
  • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
  • Turn the laptop over so its bottom is facing you.
  • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
Agregar Comentario
Using two index fingers, slide the battery latches outward.
  • Using two index fingers, slide the battery latches outward.
  • While still holding the latches out, use your thumbs to slide the battery out towards you.
  • Once the battery is dislodged, you can let go of the latches and remove the battery.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
  • Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
Agregar Comentario
Use your fingers to push out the latches holding the RAM in place.
  • Use your fingers to push out the latches holding the RAM in place.
  • The RAM should now sit up at an angle so you can safely remove it.
Agregar Comentario
Conclusión
To install the new RAM, set it in the slot at an angle and push it in until the latches reclick.
11 personas más completaron esta guía.
Jon Amireh
Miembro Desde 17/01/13
1,331 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-1, Johann Winter 2013 Miembro de Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 12
Últimos 30 Días: 24
Todo El Tiempo: 4,695
