Introducción
Not much prior knowledge is required before starting. According to Dell, however, you must have the following tools:
"‡#0 and #1 magnetized Phillips-head screwdrivers
‡ Small flat-blade screwdriver
‡ 5-mm socket wrench
‡ 7-mm socket wrench
‡ Small plastic scribe"
(Guide found at: http://tim.id.au/laptops/dell/latitude%2...)
Flip laptop over. Flip laptop over.
  • Flip laptop over.
Agregar Comentario
Remove the screws over the RAM door Remove the screws over the RAM door
  • Remove the screws over the RAM door
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Open the RAM door. Open the RAM door.
  • Open the RAM door.
Agregar Comentario
Carefully pull the tabs over the RAM chip down - the RAM will spring up. Carefully pull the tabs over the RAM chip down - the RAM will spring up.
  • Carefully pull the tabs over the RAM chip down - the RAM will spring up.
Agregar Comentario
Remove the RAM from the socket and insert replacement RAM.
  • Remove the RAM from the socket and insert replacement RAM.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Axuak
Miembro Desde 04/05/11
331 Reputación
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,052
