Saltar al contenido principal
Dell Latitude 9510 USB and Headphone Jack Replacement
Qué necesitas
  1. Dell Latitude 9510 USB and Headphone Jack Replacement, Base Panel: paso 1, imagen 1 de 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 USB and Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 USB and Headphone Jack Replacement, Fan: paso 3, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws securing the fan.
  4. Dell Latitude 9510 USB and Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Place your fingernails behind the plastic tabs on the speaker's motherboard connector, then pull directly backwards, toward the wires, until the connector releases from its port.
    • Lift the fan up and out.
  5. Dell Latitude 9510 USB and Headphone Jack Replacement, Speakers: paso 5, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  6. Dell Latitude 9510 USB and Headphone Jack Replacement: paso 6, imagen 1 de 1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
  7. Dell Latitude 9510 USB and Headphone Jack Replacement, USB and Headphone Jack Replacement: paso 7, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the four 3.5 mm screws.
  8. Dell Latitude 9510 USB and Headphone Jack Replacement: paso 8, imagen 1 de 1
    • Place your fingernails behind each of the plastic tabs on the plug, and pull directly backward until the connector releases.
  9. Dell Latitude 9510 USB and Headphone Jack Replacement: paso 9, imagen 1 de 1
    • Flip up the locking bars on the two ZIF connectors so they stand vertically, then gently remove the two ribbon cables connected to the IO daughterboard.
    • Lift the IO daughterboard up and out.
Conclusión
Matthew D
Miembro Desde 02/08/22
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 191
