Saltar al contenido principal
Dell Latitude 7420 Battery Replacement
Qué necesitas
  1. Dell Latitude 7420 Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude 7420 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
  2. Dell Latitude 7420 Battery Replacement: paso 2, imagen 1 de 2 Dell Latitude 7420 Battery Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
  3. Dell Latitude 7420 Battery Replacement: paso 3, imagen 1 de 2 Dell Latitude 7420 Battery Replacement: paso 3, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
  4. Dell Latitude 7420 Battery Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery from the motherboard by gently pulling out the connector.
  5. Dell Latitude 7420 Battery Replacement: paso 5, imagen 1 de 2 Dell Latitude 7420 Battery Replacement: paso 5, imagen 2 de 2
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
Conclusión
4 personas más completaron esta guía.
Hong Lee
Miembro Desde 05/11/21
208 Reputación
1 Guía escrita
Un comentario
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 65
Ultimos 30 días: 333
Todo El Tiempo: 10,372
