Flip your laptop over to view the bottom and locate the two locks.
  • Flip your laptop over to view the bottom and locate the two locks.
Agregar Comentario
Slide the two locks away from each other.
  • Slide the two locks away from each other.
  • Sliding these locks will loosen the battery to allow removal.
Agregar Comentario
Pull battery out of the laptop. Your laptop's battery should be completely removed.
  • Pull battery out of the laptop.
  • Your laptop's battery should be completely removed.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Flip the laptop right side up.  Open the laptop. Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
  • Flip the laptop right side up. Open the laptop.
  • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
Agregar Comentario
Gently flip the data cable latch away from the data cable with flat side of spudger. Lift the cable up and out. When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area.  When these are in place the cable is properly inserted.
  • Gently flip the data cable latch away from the data cable with flat side of spudger.
  • Lift the cable up and out.
  • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
  • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
What do I do is i broke the cable retainer wings and the black thing?
Wezley Joao Ferreira - Contestar
If the connector on the motherboard is still attached and only the clip is broken you can try and find a new clip, or perhaps tape the keyboard in place with electrical tape.
Tyler - Contestar
Close the lid, flip the laptop bottom side up with the battery at the top.
  • Close the lid, flip the laptop bottom side up with the battery at the top.
  • Remove the 11 screws holding the upper case to the lower case.
Agregar Comentario
Flip the laptop over and open the lid.
  • Flip the laptop over and open the lid.
  • Remove the two screws from the upper case.
Agregar Comentario
Gently unplug the power cable. You lift up on the dark gray latch. Pull the blue ribbon up.
  • Gently unplug the power cable.
    • You lift up on the dark gray latch.
    • Pull the blue ribbon up.
  • Gently unplug the touchpad cable.
    • Lift up on the dark gray latch.
Agregar Comentario
Grab the metal frame of the upper case and gently pull it away from the lower case. Disconnect the cable that says MB before removing the palmrest.
  • Grab the metal frame of the upper case and gently pull it away from the lower case. Disconnect the cable that says MB before removing the palmrest.
  • Work your way around the perimeter of the upper case.
Agregar Comentario
Conclusión
7 personas más completaron esta guía.
Tyler
Miembro Desde 19/06/12
3,997 Reputación
18 Guías creadas
Equipo
TechForce Miembro de TechForce
Business
2 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 20
Todo El Tiempo: 2,250
