Saltar al contenido principal
Dell Inspiron n5050 Keyboard Replacement
Qué necesitas
  1. Aviso: los pasos 1-3 provienen de una guía que está marcada como "En progreso".
    Dell Inspiron n5050 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 Keyboard Replacement: paso 3, imagen 1 de 2 Dell Inspiron n5050 Keyboard Replacement: paso 3, imagen 2 de 2
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 Dell Inspiron n5050 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 Keyboard Replacement: paso 5, imagen 1 de 3 Dell Inspiron n5050 Keyboard Replacement: paso 5, imagen 2 de 3 Dell Inspiron n5050 Keyboard Replacement: paso 5, imagen 3 de 3
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
Conclusión
4 personas más completaron esta guía.
Tyler
Miembro Desde 06/19/12
4,920 Reputación
16 Guías creadas
Equipo
TechForce Miembro de TechForce
Business
2 Miembros
25 Guías creadas
4 comentarios
dis has realy helped me sir... love you!
jovialcom - Contestar
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
https://youtu.be/3c5P0pJgckg
mohamed - Contestar
Here’s a video guide to replacing the keyboard on this (or similar) laptop: https://www.youtube.com/watch?v=6T3xgkC-...
Paul Freeman-Powell - Contestar
My keyboard is not have a clips what i do?
BurIsm - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 19
Todo El Tiempo: 9,835
