Saltar al contenido principal
Dell Inspiron E1705 Upper Case and Screen Replacement
Qué necesitas
  1. Dell Inspiron E1705 Upper Case and Screen Replacement, Upper Case and Screen: paso 1, imagen 1 de 1
    • Use a spudger to remove the six rubber nibs and 2 plastic pieces on the bezel of the display.
    • Remove the eight Phillips #0 screws hidden under the rubber nibs and plastic pieces.
  2. Dell Inspiron E1705 Upper Case and Screen Replacement: paso 2, imagen 1 de 2 Dell Inspiron E1705 Upper Case and Screen Replacement: paso 2, imagen 2 de 2
    • Pry the plastic bezel from the back plate using a plastic opening tool.
    • Remove the plastic bezel entirely and set it aside.
  3. Dell Inspiron E1705 Upper Case and Screen Replacement: paso 3, imagen 1 de 2 Dell Inspiron E1705 Upper Case and Screen Replacement: paso 3, imagen 2 de 2
    • Remove the 4 screws along the left and right sides of the screen. There are 8 screws in total.
  4. Dell Inspiron E1705 Upper Case and Screen Replacement: paso 4, imagen 1 de 2 Dell Inspiron E1705 Upper Case and Screen Replacement: paso 4, imagen 2 de 2
    • Use the spudger to separate the screen from the back case.
    • Hold the screen in one hand and tilt the back case away from you.
    • The screen is connected to the back case by two leads.
  5. Dell Inspiron E1705 Upper Case and Screen Replacement: paso 5, imagen 1 de 2 Dell Inspiron E1705 Upper Case and Screen Replacement: paso 5, imagen 2 de 2
    • Remove the two leads from the screen. They will stay connected to the computer.
    • Do not touch the white tape on your replacement monitor.
    • Remove the screen carefully.
Conclusión
9 personas más completaron esta guía.
Equipo
Cal Poly, Team 22-5, Maness Fall 2010 Miembro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 6,994
