Saltar al contenido principal
Dell Inspiron 9100 Optical Drive/Accessory Device Replacement
Qué necesitas
  1. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: paso 1, imagen 3 de 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: paso 2, imagen 1 de 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: paso 2, imagen 2 de 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: paso 2, imagen 3 de 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: paso 3, imagen 1 de 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: paso 3, imagen 2 de 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: paso 3, imagen 3 de 3
    • Press the tab on the outside face of the optical drive to release a handle.
    • Pull the handle to eject the optical drive unit from the slot, and slide it out.
Conclusión
charlierefvem
Miembro Desde 01/11/11
854 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 13-2, Forte Winter 2011 Miembro de Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 2,227
