Introducción
This guide requires a Phillips #00 screwdriver
Partes
No se requieren partes.
Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
  • Unplug the laptop from the power adapter and turn the power off.
  • Failure to unplug laptop before proceeding could result in risk of electric shock!
Agregar Comentario
Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
  • Slide the battery-lock tab and hold.
  • Flip the battery away from the chassis to remove it.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Undo the screw on the Mini-PCI card cover labeled "C" This screw will remain within the panel
  • Undo the screw on the Mini-PCI card cover labeled "C"
  • This screw will remain within the panel
  • Remove the panel from the chassis.
Agregar Comentario
Disconnect the antenna cables from the Mini-PCI card.
  • Disconnect the antenna cables from the Mini-PCI card.
Agregar Comentario
Use your fingertips to carefully spread apart the white plastic tabs. Flip the Mini-PCI card up at a 45 degree angle. Remove the card from the computer by sliding out diagonally
  • Use your fingertips to carefully spread apart the white plastic tabs.
  • Flip the Mini-PCI card up at a 45 degree angle.
  • Remove the card from the computer by sliding out diagonally
  • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
charlierefvem
Miembro Desde 11/01/11
854 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 13-2, Forte Winter 2011 Miembro de Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 9
Todo El Tiempo: 3,956
