Introducción
This guide requires a Phillips #00 screwdriver
Partes
No se requieren partes.
Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
  • Unplug the laptop from the power adapter and turn the power off.
  • Failure to unplug laptop before proceeding could result in risk of electric shock!
Agregar Comentario
Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
  • Slide the battery-lock tab and hold.
  • Flip the battery away from the chassis to remove it.
Agregar Comentario
Turn the laptop around.
  • Turn the laptop around.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use your fingers to gently pull up on the hinge covers.  They will release with an audible snap. Fold the screen back to 180 degrees. Using your index fingers, pull up the hinge cover.
  • Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
  • Fold the screen back to 180 degrees.
  • Using your index fingers, pull up the hinge cover.
Agregar Comentario
After the hinges pop, pull the hinge cover gently. Pull the clear tab on the right side of the laptop up.  This tab will disconnect the hinge cover from the laptop. Pull the clear tab on the right side of the laptop up.  This tab will disconnect the hinge cover from the laptop.
  • After the hinges pop, pull the hinge cover gently.
  • Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
Agregar Comentario
Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
  • Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
Agregar Comentario
Tilt the keyboard away from the screen. Pull up on the white tab underneath the keyboard to release the keyboard. Pull up on the white tab underneath the keyboard to release the keyboard.
  • Tilt the keyboard away from the screen.
  • Pull up on the white tab underneath the keyboard to release the keyboard.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Ana
Miembro Desde 11/01/11
111 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-2, Forte Winter 2011 Miembro de Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 6
Todo El Tiempo: 3,623
