Saltar al contenido principal
Dell Inspiron 910 RAM Replacement
Qué necesitas
  1. Dell Inspiron 910 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 RAM Replacement, Preparation: paso 2, imagen 1 de 1
    • Remember to power off the device before starting!
    • Disconnect any cables or external devices from the laptop, then flip it and remove the battery by pressing the battery tabs inward.
  3. Dell Inspiron 910 RAM Replacement: paso 3, imagen 1 de 1
    • Locate the large black panel with two screws holding it in place. (This is the panel with ventilation holes)
    • Unscrew both of the screws using a Philips Screwdriver.
  4. Dell Inspiron 910 RAM Replacement: paso 4, imagen 1 de 1
    • Remove the panel by pulling upward.
    • Removal may require some force!
  5. Dell Inspiron 910 RAM Replacement: paso 5, imagen 1 de 2 Dell Inspiron 910 RAM Replacement: paso 5, imagen 2 de 2
    • After removing the panel, locate the memory modules.
    • Look for the silver tabs on either side of the white plastic holding the RAM in place. Then gently remove the RAM.
  6. Dell Inspiron 910 RAM Replacement, For Reinstallation: paso 6, imagen 1 de 1
    • Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
    • Congratulations! You have completed the guide.
Conclusión
4 personas más completaron esta guía.
Kyle Beekman
Miembro Desde 04/05/12
144 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-10, Forte Spring 2012 Miembro de Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,866
