Introducción
If the RAM is not working, follow this guide.
Partes
No se requieren partes.
Remove the battery from the bottom of the laptop.
  • Remove the battery from the bottom of the laptop.
  • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
  • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove memory cover on bottom of laptop.
Agregar Comentario
Pull apart the white plastic tabs on either side of the RAM which will cause it to rise upwards. Gently remove the RAM, only touching the edges of the component.
  • Pull apart the white plastic tabs on either side of the RAM which will cause it to rise upwards.
  • Gently remove the RAM, only touching the edges of the component.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Brian Murphy
Miembro Desde 13/04/11
347 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-22, Garner Spring 2011 Miembro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Miembros
15 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 4,107
