Introducción
We will show you how to remove and replace the hinge cover which houses the power button.
Partes
No se requieren partes.
Remove the battery from the bottom of the laptop.
  • Remove the battery from the bottom of the laptop.
  • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
  • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Locate the small opening at the upper left of the top blue panel which houses the power button. Use a spudger to lift up and remove the blue panel. Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  • Locate the small opening at the upper left of the top blue panel which houses the power button.
  • Use a spudger to lift up and remove the blue panel.
  • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
Agregar Comentario
Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
  • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
  • You should now be able to completely remove the hinge cover.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Brian Murphy
Miembro Desde 13/04/11
347 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-22, Garner Spring 2011 Miembro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Miembros
15 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 21
Todo El Tiempo: 3,724
