Introducción
If you are having difficulties with the keyboard, please follow this guide.
Partes
No se requieren partes.
Remove the battery from the bottom of the laptop.
  • Remove the battery from the bottom of the laptop.
  • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
  • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
Agregar Comentario
Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off. Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover. Be careful of wire attached to underside of the hinge cover.
  • Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
  • Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
  • Be careful of wire attached to underside of the hinge cover.
Agregar Comentario
Pull the small black tab on the right hand side of the laptop.
  • Pull the small black tab on the right hand side of the laptop.
  • The hinge cover has now been removed.
Agregar Comentario
Remove the screws at the top of the keyboard as indicated indicated. Do not just lift up, there is a tab underneath the keyboard that is still connected to the mother board. You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
  • Remove the screws at the top of the keyboard as indicated indicated.
  • Do not just lift up, there is a tab underneath the keyboard that is still connected to the mother board.
  • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
  • The keyboard should be easily removable at this point.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Perry
Miembro Desde 12/04/11
239 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-22, Garner Spring 2011 Miembro de Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Miembros
15 Guías creadas
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 3,318
