Introducción
This guide is will show how to replace a faulty hard drive.
Partes
No se requieren partes.
Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily.
  • Push in the tab on the battery and lift up. The battery should detach very easily.
Agregar Comentario
The hard drive is located here.
  • The hard drive is located here.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
Agregar Comentario
Pull the hard drive tray directly away from the computer. The tray should slide out easily.
  • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Todd
Miembro Desde 05/04/11
86 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-40, Forte Spring 2011 Miembro de Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Miembros
8 Guías creadas
What size is the hard drive, you know, to buy a new one?
Ethan White - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 57
Todo El Tiempo: 13,446
