Introducción
Before removing the RAM you will need to remove your battery.
Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily.
  • Push in the tab on the battery and lift up. The battery should detach very easily.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Remove the single screw securing the RAM compartment and pull up to reveal the RAM. Remove the single screw securing the RAM compartment and pull up to reveal the RAM. Remove the single screw securing the RAM compartment and pull up to reveal the RAM.
  • Remove the single screw securing the RAM compartment and pull up to reveal the RAM.
Agregar Comentario
Push on the small white metal tabs on both sides of a module to unlock it. The RAM should be stick out at approximately a 45 degree angle. Grasp the RAM by the sides and pull straight out to remove it. If the RAM sticks slightly, wiggle it back and forth gently to loosen it.
  • Push on the small white metal tabs on both sides of a module to unlock it.
  • The RAM should be stick out at approximately a 45 degree angle. Grasp the RAM by the sides and pull straight out to remove it.
    • If the RAM sticks slightly, wiggle it back and forth gently to loosen it.
Agregar Comentario
Conclusión
Taylor Woods
Miembro Desde 05/04/11
101 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-40, Forte Spring 2011 Miembro de Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 7
Todo El Tiempo: 3,564
