Partes
No se requieren partes.
Flip to the back side of the laptop
  • Flip to the back side of the laptop
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Loosen one screw.
  • Loosen one screw.
  • This screw is attached to the panel and cannot be removed.
Agregar Comentario
Spread out pins on the opposite sides. The chip will spring up at an angle. Place new chip in at a 30 degree angle. Push inward until pins can't be seen.
  • Spread out pins on the opposite sides. The chip will spring up at an angle.
  • Place new chip in at a 30 degree angle.
  • Push inward until pins can't be seen.
  • Push RAM down, so it lays flat.
  • Improperly replacing the RAM will cause it to short-circuit.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
May Chauvin
Miembro Desde 14/04/11
186 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 12-34, Maness Spring 2011 Miembro de Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 5
Últimos 30 Días: 16
Todo El Tiempo: 3,470
