Saltar al contenido principal
Dell Inspiron 17-5749 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 17-5749 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 17-5749 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17-5749 Keyboard Replacement: paso 2, imagen 2 de 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  4. Dell Inspiron 17-5749 Keyboard Replacement: paso 4, imagen 1 de 1
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
Conclusión
Christopher Tran
Miembro Desde 02/13/18
1,161 Reputación
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 422
