Saltar al contenido principal
Dell Inspiron 1545 Motherboard Replacement
Qué necesitas
  1. Dell Inspiron 1545 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Motherboard Replacement: paso 2, imagen 1 de 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Motherboard Replacement: paso 3, imagen 1 de 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Motherboard Replacement, Center Control Cover: paso 4, imagen 1 de 1
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  5. Dell Inspiron 1545 Motherboard Replacement: paso 5, imagen 1 de 1
    • Flip the laptop over to the front and open the display as far as possible.
  6. Dell Inspiron 1545 Motherboard Replacement: paso 6, imagen 1 de 3 Dell Inspiron 1545 Motherboard Replacement: paso 6, imagen 2 de 3 Dell Inspiron 1545 Motherboard Replacement: paso 6, imagen 3 de 3
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  7. Dell Inspiron 1545 Motherboard Replacement, Base Cover: paso 7, imagen 1 de 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  8. Dell Inspiron 1545 Motherboard Replacement: paso 8, imagen 1 de 2 Dell Inspiron 1545 Motherboard Replacement: paso 8, imagen 2 de 2
    • Carefully lift the base cover vertically away from the laptop.
  9. Dell Inspiron 1545 Motherboard Replacement, CPU Heat Sink: paso 9, imagen 1 de 1
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  10. Dell Inspiron 1545 Motherboard Replacement: paso 10, imagen 1 de 1
    • Pull up on the Heat Sink unit to remove it.
  11. Dell Inspiron 1545 Motherboard Replacement, Keyboard: paso 11, imagen 1 de 1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  12. Dell Inspiron 1545 Motherboard Replacement: paso 12, imagen 1 de 1
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  13. Dell Inspiron 1545 Motherboard Replacement: paso 13, imagen 1 de 1
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
  14. Dell Inspiron 1545 Motherboard Replacement: paso 14, imagen 1 de 1
    • Lift the keyboard up and away from the laptop.
  15. Dell Inspiron 1545 Motherboard Replacement, Palm Rest: paso 15, imagen 1 de 1
    • Remove the 11 screws (5mm Phillips #1) from the back of the laptop as marked. One screw is in the middle, by the RAM.
  16. Dell Inspiron 1545 Motherboard Replacement: paso 16, imagen 1 de 1
    • Remove black and white wires from the WLAN that lead to the display by pulling straight up.
    • Unwind the wires from the routing guides.
  17. Dell Inspiron 1545 Motherboard Replacement: paso 17, imagen 1 de 1
    • Turn the laptop back over to its normal resting position and pull the black and white wires previously connected to the WLAN through the hole.
    • Remove the 4 smaller screws (5mm Phillips #1) and one screw on the top left (3mm Phillips #1) from the palm rest.
  18. Dell Inspiron 1545 Motherboard Replacement: paso 18, imagen 1 de 1
    • Disconnect the Bluetooth card cable, Wed cable, Camera1 cable, power cable, and touchpad cable from the respective Motherboard connectors as marked. For the Bluetooth cable and Camera1 cable, pull the plugs towards the screen. For the touchpad and power cable, lift the black tab and then pull them out. For the Wed cable, pull the blue tab up.
    • Unsecure the wires from the routing guides so they are loose.
    • Pull on the plastic tabs for each connector to help prevent causing damage to the connectors.
  19. Dell Inspiron 1545 Motherboard Replacement: paso 19, imagen 1 de 1
    • To separate the palm rest from the rest of the computer, use a plastic opening tool to lift up the plastic. It is best to start at one point and work your way around.
  20. Dell Inspiron 1545 Motherboard Replacement, Optical Disk Drive: paso 20, imagen 1 de 1
    • Flip the laptop to its back side.
    • Remove the screw (5mm Phillips #1) that secures the Optical Disk Drive on the back of the laptop.
  21. Dell Inspiron 1545 Motherboard Replacement: paso 21, imagen 1 de 3 Dell Inspiron 1545 Motherboard Replacement: paso 21, imagen 2 de 3 Dell Inspiron 1545 Motherboard Replacement: paso 21, imagen 3 de 3
    • Push the Optical Disk Drive out using a spudger tool as shown and pull from the front cover of the Optical Disk Drive.
  22. Dell Inspiron 1545 Motherboard Replacement, Daughter Board: paso 22, imagen 1 de 1
    • Remove the 3 screws (3mm Phillips #1) that secure the daughter board to the motherboard.
    • Lift the daughter board away from the laptop.
  23. Dell Inspiron 1545 Motherboard Replacement, Motherboard: paso 23, imagen 1 de 1
    • Remove the two screws (3mm, Phillips #1) on the left and the two screws (5mm, Phillips #1) on the right that secure the Motherboard to the laptop.
  24. Dell Inspiron 1545 Motherboard Replacement: paso 24, imagen 1 de 1
    • Disconnect the Thermal Fan cable, Speaker cable, and USB Board cable from their connectors.
  25. Dell Inspiron 1545 Motherboard Replacement: paso 25, imagen 1 de 1
    • To remove the Motherboard, pull away and up from the base of the laptop.
    • Along with removing the Motherboard if you haven’t already done so, the auxiliary port cover on the front will come off with it as well.
Conclusión
22 personas más completaron esta guía.
Nathan Lemay
Miembro Desde 04/16/14
3,052 Reputación
15 Guías creadas
Equipo
Cal Poly, Team 9-14, Regan Spring 2014 Miembro de Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Miembros
15 Guías creadas
2 comentarios
Thank you so much for the guide extremely helpful
Jonathan Bluesword - Contestar
im trying to find out for sure with out any question at all that this motherboard is infact the right one i am paying for… i want my old laptop to work like brand new as it did about four weeks ago.. granted it had windows 7 at the time of mr, laxton i hope that you can offer me a complete windows 10 updates.. seems like every where we try and move too..when we do move ..it dont take long to set it up//as long as they keep
Scott D Laxton - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 46
Todo El Tiempo: 9,770
