Saltar al contenido principal
Dell Inspiron 1545 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 1545 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Keyboard Replacement: paso 3, imagen 1 de 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Keyboard Replacement, Base Cover: paso 4, imagen 1 de 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Inspiron 1545 Keyboard Replacement: paso 5, imagen 2 de 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Keyboard Replacement, Center Control Cover: paso 6, imagen 1 de 1
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  7. Dell Inspiron 1545 Keyboard Replacement: paso 7, imagen 1 de 1
    • Flip the laptop over to the front and open the display as far as possible.
  8. Dell Inspiron 1545 Keyboard Replacement: paso 8, imagen 1 de 3 Dell Inspiron 1545 Keyboard Replacement: paso 8, imagen 2 de 3 Dell Inspiron 1545 Keyboard Replacement: paso 8, imagen 3 de 3
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  9. Dell Inspiron 1545 Keyboard Replacement, Keyboard: paso 9, imagen 1 de 1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  10. Dell Inspiron 1545 Keyboard Replacement: paso 10, imagen 1 de 1
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  11. Dell Inspiron 1545 Keyboard Replacement: paso 11, imagen 1 de 1
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
  12. Dell Inspiron 1545 Keyboard Replacement: paso 12, imagen 1 de 1
    • Lift the keyboard up and away from the laptop.
Conclusión
15 personas más completaron esta guía.
Nathan Lemay
Miembro Desde 04/16/14
3,052 Reputación
15 Guías creadas
Equipo
Cal Poly, Team 9-14, Regan Spring 2014 Miembro de Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Miembros
15 Guías creadas
2 comentarios
Step 4 and 5 are not needed.
James Thrun - Contestar
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 6,860
