Saltar al contenido principal
Dell Inspiron 1545 Display Replacement
Qué necesitas
  1. Dell Inspiron 1545 Display Replacement, Battery: paso 1, imagen 1 de 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Display Replacement: paso 2, imagen 1 de 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Display Replacement: paso 3, imagen 1 de 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Display Replacement, Center Control Cover: paso 4, imagen 1 de 1
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  5. Dell Inspiron 1545 Display Replacement: paso 5, imagen 1 de 1
    • Flip the laptop over to the front and open the display as far as possible.
  6. Dell Inspiron 1545 Display Replacement: paso 6, imagen 1 de 3 Dell Inspiron 1545 Display Replacement: paso 6, imagen 2 de 3 Dell Inspiron 1545 Display Replacement: paso 6, imagen 3 de 3
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  7. Dell Inspiron 1545 Display Replacement, Keyboard: paso 7, imagen 1 de 1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  8. Dell Inspiron 1545 Display Replacement: paso 8, imagen 1 de 1
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  9. Dell Inspiron 1545 Display Replacement: paso 9, imagen 1 de 1
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
  10. Dell Inspiron 1545 Display Replacement: paso 10, imagen 1 de 1
    • Lift the keyboard up and away from the laptop.
  11. Dell Inspiron 1545 Display Replacement, Display: paso 11, imagen 1 de 1
    • Remove the two screws (5.5mm, Phillips #1) from the laptop base.
  12. Dell Inspiron 1545 Display Replacement: paso 12, imagen 1 de 1
    • Remove black and white wires from the WLAN that lead to the display by pulling straight up.
    • Unwind the wires so they can be freely pulled through in the next step.
  13. Dell Inspiron 1545 Display Replacement: paso 13, imagen 1 de 1
    • Turn the laptop over to its standard position.
    • Disconnect the Wed cable and Camera1 cable from the respective Motherboard connectors as marked. Unsecure the wires so they are loose.
    • Pull the black and white wires previously connected to the WLAN through the hole.
  14. Dell Inspiron 1545 Display Replacement: paso 14, imagen 1 de 1
    • Remove the Camera1 cable, the Wed cable, and the black and white wires from the routing guides.
    • Remove the four screws (5mm Phillips #1) (two on either side) that secure the display assembly.
  15. Dell Inspiron 1545 Display Replacement: paso 15, imagen 1 de 1
    • Lift the display assembly off the computer.
Conclusión
10 personas más completaron esta guía.
Nathan Lemay
Miembro Desde 04/16/14
3,052 Reputación
15 Guías creadas
Equipo
Cal Poly, Team 9-14, Regan Spring 2014 Miembro de Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Miembros
15 Guías creadas
3 comentarios
wow that is really good
Mck - Isolutions - Contestar
AWESOME, but how to know if display is faulty or some issue in the other device causing blank screen
Kumar Bhrigu - Contestar
put it back toghther, then plug in a external monitor
Feyrowan -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 30
Todo El Tiempo: 5,535
