Introducción
Use this guide to help you replace the upper case on a Dell Inspiron 1525.
Partes
No se requieren partes.
Locate the battery release switch on the bottom of the laptop.
  • Locate the battery release switch on the bottom of the laptop.
Agregar Comentario
Slide the battery release switch away from the lock symbol until you hear the battery click. Slide the battery towards the back of the laptop until it comes free.
  • Slide the battery release switch away from the lock symbol until you hear the battery click.
  • Slide the battery towards the back of the laptop until it comes free.
Agregar Comentario
Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
Agregar Comentario
Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up. Carefully pull the central control cover up along its edges. Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
  • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
Agregar Comentario
Peel back the silver tape securing the ribbon cable to the cover. Pull the small brown latch on the ribbon cable connector out. Disconnect the ribbon cable to completely free the central control cover.
  • Peel back the silver tape securing the ribbon cable to the cover.
  • Pull the small brown latch on the ribbon cable connector out.
  • Disconnect the ribbon cable to completely free the central control cover.
Agregar Comentario
Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop. Gently slide the keyboard towards the display until the tabs on its front side are free.
  • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
  • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
Agregar Comentario
Use a spudger to gently lift the ribbon cable retaining flap. Disconnect the ribbon cable.
  • Use a spudger to gently lift the ribbon cable retaining flap.
  • Disconnect the ribbon cable.
  • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
the flap broke? the little black piece. Now what do i do? I'm stuck at this step
daaaammon - Contestar
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel. The screws may only need to be loosened, as they are generally retained by plastic washers.
  • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
  • Remove the bottom panel.
Agregar Comentario
Disconnect the five antennas from their respective cards. De-route the antennas from their routing retainers. De-route the antennas from their routing retainers.
  • Disconnect the five antennas from their respective cards.
  • De-route the antennas from their routing retainers.
Agregar Comentario
Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
  • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
Agregar Comentario
Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector. Carefully release the connector from its retaining tabs. Carefully release the connector from its retaining tabs.
  • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
  • Carefully release the connector from its retaining tabs.
Agregar Comentario
Push the antenna wires up through their hole in the bottom case half. Release the antennas from their retaining tabs on the upper case.
  • Push the antenna wires up through their hole in the bottom case half.
  • Release the antennas from their retaining tabs on the upper case.
Agregar Comentario
Disconnect the flat LCD ribbon cable by pulling it up by the tab. Free the ribbon cable from its retaining clips.
  • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
  • Free the ribbon cable from its retaining clips.
Agregar Comentario
Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
  • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
  • Remove the display assembly from the laptop.
Agregar Comentario
Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop. Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
  • Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop.
  • Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
Agregar Comentario
Use a spudger to pull the touch pad connector latch towards the ribbon cable. Pull the ribbon cable out of the connector.
  • Use a spudger to pull the touch pad connector latch towards the ribbon cable.
  • Pull the ribbon cable out of the connector.
Agregar Comentario
Use a spudger to pull the device status LED connector latch towards the ribbon cable. Disconnect the device status LED ribbon cable.
  • Use a spudger to pull the device status LED connector latch towards the ribbon cable.
  • Disconnect the device status LED ribbon cable.
Agregar Comentario
Release the ribbon cable in the upper left corner of the laptop from its retaining tabs. Use a spudger to unplug the speaker connector at the top center of the laptop. De-route the speaker wires from their retaining tabs.
  • Release the ribbon cable in the upper left corner of the laptop from its retaining tabs.
  • Use a spudger to unplug the speaker connector at the top center of the laptop.
  • De-route the speaker wires from their retaining tabs.
Agregar Comentario
Use the flat end of a spudger to begin lifting the upper case at its front edge. Lift the front edge of the case up until it comes free.
  • Use the flat end of a spudger to begin lifting the upper case at its front edge.
  • Lift the front edge of the case up until it comes free.
    • Work slowly and be sure not to get any cables caught in the upper case holes and guides.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 8
Últimos 30 Días: 47
Todo El Tiempo: 10,231
