Saltar al contenido principal
Dell Inspiron 1521 DVD Drive Replacement
Qué necesitas
  1. Dell Inspiron 1521 DVD Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 DVD Drive Replacement: paso 2, imagen 1 de 3 Dell Inspiron 1521 DVD Drive Replacement: paso 2, imagen 2 de 3 Dell Inspiron 1521 DVD Drive Replacement: paso 2, imagen 3 de 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: paso 3, imagen 1 de 2 Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: paso 3, imagen 2 de 2
    • Locate the 4 mm Phillips #1 screw next to the white padlock image that holds the DVD drive in place.
    • Remove this screw with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 DVD Drive Replacement: paso 4, imagen 1 de 3 Dell Inspiron 1521 DVD Drive Replacement: paso 4, imagen 2 de 3 Dell Inspiron 1521 DVD Drive Replacement: paso 4, imagen 3 de 3
    • Use a plastic opener tool to carefully pry the DVD drive out of its pocket on the side of the laptop.
    • Once sticking out, pull the DVD drive the rest of the way out with your hand.
Conclusión
Equipo
Cal Poly, Team 15-47, Forte Fall 2012 Miembro de Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 990
