Saltar al contenido principal
Dell Inspiron 15-5567 Battery Replacement
Qué necesitas
  1. Dell Inspiron 15-5567 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
  2. Dell Inspiron 15-5567 Battery Replacement: paso 2, imagen 1 de 3 Dell Inspiron 15-5567 Battery Replacement: paso 2, imagen 2 de 3 Dell Inspiron 15-5567 Battery Replacement: paso 2, imagen 3 de 3
    • Slide the DVD drive out of the laptop.
    • Remove the three screws underneath using a micro screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Battery Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15-5567 Battery Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the two screws attached to the metal bracket holding down the battery.
    • Remove the screw attached to the laptop battery using a Phillips #0 screwdriver.
  4. Dell Inspiron 15-5567 Battery Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-5567 Battery Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery connecting cable from the laptop by sliding it out.
    • Confirm the new battery is correct for this laptop model by looking at the battery type and power.
  5. Dell Inspiron 15-5567 Battery Replacement: paso 5, imagen 1 de 2 Dell Inspiron 15-5567 Battery Replacement: paso 5, imagen 2 de 2
    • Attach the cable for the new battery to the laptop by sliding the cable into the port.
Conclusión
5 personas más completaron esta guía.
Un comentario
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
Kat Vinson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 24
Ultimos 30 días: 109
Todo El Tiempo: 7,420
