Saltar al contenido principal
Dell Inspiron 15-5548 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Open up the front of the laptop.
    • Locate the 5 holes at the top of the keyboard, as circled in Picture 2.
    • Use the metal spudger to pry up the keyboard at each of the 5 points.
    • This may take some extra force, and it should pop when it is pried off.
  2. Dell Inspiron 15-5548 Keyboard Replacement: paso 2, imagen 1 de 3 Dell Inspiron 15-5548 Keyboard Replacement: paso 2, imagen 2 de 3 Dell Inspiron 15-5548 Keyboard Replacement: paso 2, imagen 3 de 3
    • When all the points have been pried up, gently lift the keyboard.
    • Lift the ZIF tabs holding down the two ribbon cables, and gently remove them.
    • Remove the keyboard.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 30
Todo El Tiempo: 1,566
