Saltar al contenido principal
Dell Inspiron 14z Memory module Replacement
Qué necesitas
  1. Dell Inspiron 14z Memory module Replacement, Memory module: paso 1, imagen 1 de 3 Dell Inspiron 14z Memory module Replacement, Memory module: paso 1, imagen 2 de 3 Dell Inspiron 14z Memory module Replacement, Memory module: paso 1, imagen 3 de 3
    • Here is a Dell Inspiron 14z N411z that is going to get a new memory module.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Memory module Replacement: paso 2, imagen 1 de 3 Dell Inspiron 14z Memory module Replacement: paso 2, imagen 2 de 3 Dell Inspiron 14z Memory module Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come of.
  3. Dell Inspiron 14z Memory module Replacement: paso 3, imagen 1 de 3 Dell Inspiron 14z Memory module Replacement: paso 3, imagen 2 de 3 Dell Inspiron 14z Memory module Replacement: paso 3, imagen 3 de 3
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
    • With the securing clips spread, the memory module will pop up.
    • Remove the memory module and replace as needed.
Conclusión
Una persona más ha completado esta guía.
oldturkey03
Miembro Desde 09/29/10
784,351 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
560 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,800
