Saltar al contenido principal
Dell Inspiron 13-7352 Cooling Fan Replacement
Qué necesitas
  1. Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: paso 1, imagen 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Cooling Fan Replacement: paso 2, imagen 1 de 2 Dell Inspiron 13-7352 Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Cooling Fan Replacement: paso 3, imagen 1 de 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: paso 4, imagen 1 de 2 Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: paso 4, imagen 2 de 2
    • Remove the cord that runs from system board to the I/O board.
  5. Dell Inspiron 13-7352 Cooling Fan Replacement: paso 5, imagen 1 de 2 Dell Inspiron 13-7352 Cooling Fan Replacement: paso 5, imagen 2 de 2
    • Remove the 3mm and 4mm screws holding down fan with the Phillips #0 head.
    • Disconnect the fan wire from the system board.
  6. Dell Inspiron 13-7352 Cooling Fan Replacement: paso 6, imagen 1 de 1
    • Lift the fan from the rest of the device by picking up a single side and separating it from device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 2,211
