Introducción
Replace the interface buttons if they have fallen out or are worn out from usage.
Qué necesitas
Lay the monitor screen-down so the back screws are exposed.
Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
Locate the two holes on the bottom of the monitor.
Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
Continue prying along the entire edge of the monitor.
Behind the front panel of the plastic cover lies the button strip.
Remove the buttons by gently pulling up on the strip.
Una persona más ha completado esta guía.
