Introducción
This guide will show you how to remove and replace the charging port for your Chromebook 3180.
Remove the 7 screws from the back cover with a Phillips #0 screwdriver Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
  • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
  • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
Agregar Comentario
  • Using a Phillips #0, remove the 2 screws from the right side hinge.
  • Lift the chromebook base in order to force the hinge in an upward position. This will provide you enough room to remove the charging port.
  • Remove the 2 charging port screws
  • Unplug the charging port connector from the Motherboard
Agregar Comentario
Free Shipping on all orders USD79.00 and up.
Visita Nuestra Tienda
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
  • Disconnect the charging port connector from the motherboard.
  • Replace the charging port if needed by connecting the new charging port connector to the motherboard.
  • Using a Phillips#0, replace the 2 charging port screws.
Agregar Comentario
  • Reset the right side hinge back into place by pressing down so the hinge is flush against the chromebook base.
  • Secure with the 2 screws using your phillips #0.
Agregar Comentario
Secure all 7 screws with a Phillips #0
  • Secure all 7 screws with a Phillips #0
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Jon
Miembro Desde 18/08/13
2,476 Reputación
16 Guías creadas
Hey Party Person, nice job. I believe you might be the greatest tech to ever hold a screw driver. This song is for you https://youtu.be/ItWIYcD6jas
foshizol - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 10
Últimos 30 Días: 37
Todo El Tiempo: 120
