Saltar al contenido principal
Dell Chromebook 13-7310 Cooling Fan Replacement
Qué necesitas
  1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: paso 3, imagen 1 de 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: paso 3, imagen 2 de 2
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  4. Dell Chromebook 13-7310 Cooling Fan Replacement: paso 4, imagen 1 de 2 Dell Chromebook 13-7310 Cooling Fan Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
Conclusión
Congratulations! You have successfully removed the cooling fan of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 483
