Saltar al contenido principal
Dell Chromebook 11 3180 Speakers Replacement
Qué necesitas
  1. Dell Chromebook 11 3180 Speakers Replacement, Back Cover: paso 1, imagen 1 de 1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Speakers Replacement: paso 2, imagen 1 de 1
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Speakers Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Speakers Replacement: paso 4, imagen 1 de 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Speakers Replacement: paso 5, imagen 1 de 1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Speakers Replacement, Speakers: paso 6, imagen 1 de 3 Dell Chromebook 11 3180 Speakers Replacement, Speakers: paso 6, imagen 2 de 3 Dell Chromebook 11 3180 Speakers Replacement, Speakers: paso 6, imagen 3 de 3
    • Locate and gently pull the wire harness (small plastic box with wires leading to black audio speakers) directly out of the connector on the motherboard.
    • Some components are not shown in pictures for simplicity. There is no need to remove any of the missing components to successfully remove the speakers.
  7. Dell Chromebook 11 3180 Speakers Replacement: paso 7, imagen 1 de 3 Dell Chromebook 11 3180 Speakers Replacement: paso 7, imagen 2 de 3 Dell Chromebook 11 3180 Speakers Replacement: paso 7, imagen 3 de 3
    • Remove any existing tape attached to the audio wire you unplugged in the previous step.
    • Gently lift and remove speakers.
    • No screws should be removed
Conclusión
3 personas más completaron esta guía.
George Erie
Miembro Desde 04/26/17
327 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S22-G1, Livingston Spring 2017 Miembro de Cal Poly, Team S22-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G1
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 648
