Saltar al contenido principal
Dell Chromebook 11 3180 Battery Replacement
Qué necesitas
  1. Dell Chromebook 11 3180 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Set your laptop upside down on your work space.
  2. Dell Chromebook 11 3180 Battery Replacement: paso 2, imagen 1 de 1
    • Using tweezers, remove the circular stickers that are covering the two screws near the middle of the back cover. Stick them to the laptop next to the screws.
  3. Dell Chromebook 11 3180 Battery Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #0 screwdriver, loosen all seven 2.5mm screws on the back cover of the device.
    • These screws will stay attached to the back cover, so just loosen them until they rattle around.
  4. Dell Chromebook 11 3180 Battery Replacement: paso 4, imagen 1 de 1
    • Using a plastic opening tool, begin to separate the back cover from the body of the computer.
    • If you have trouble prying a particular part of the back cover off, make sure that the nearest screws are fully loosened.
  5. Dell Chromebook 11 3180 Battery Replacement: paso 5, imagen 1 de 1
    • Using your hands, pull the back cover fully off of the body of the computer.
  6. Dell Chromebook 11 3180 Battery Replacement, Battery: paso 6, imagen 1 de 2 Dell Chromebook 11 3180 Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Unplug the battery from the motherboard by gently pulling the black cable header from the motherboard towards the battery.
    • You can locate this cable by checking that its other end connects to the battery. It has black protective wrap.
  7. Dell Chromebook 11 3180 Battery Replacement: paso 7, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove each of the three 3mm screws from the battery.
  8. Dell Chromebook 11 3180 Battery Replacement: paso 8, imagen 1 de 1
    • Lift the battery away from the computer to remove it.
    • If there is any resistance to the battery being removed, make sure that all of the screws have been properly removed and that nothing is blocking the battery.
Conclusión
8 personas más completaron esta guía.
Devon Paul
Miembro Desde 04/26/17
1,206 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S22-G1, Livingston Spring 2017 Miembro de Cal Poly, Team S22-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G1
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 5,488
