Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Partes
No se requieren partes.
WARNING:  Before working inside your computer, read the safety information  that shipped with your computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Loosen the three captive screws that se cure the hard-drive assembly to the computer base.
Agregar Comentario
Using the pull-tab, lift the hard-drive assembly to disconnect it from the  connector on the system board.
  • Using the pull-tab, lift the hard-drive assembly to disconnect it from the connector on the system board.
Agregar Comentario
Lift the hard-drive assembly out of the computer base.
  • Lift the hard-drive assembly out of the computer base.
Agregar Comentario
Remove the four screws that secure the hard drive to the hard-drive  bracket.
  • Remove the four screws that secure the hard drive to the hard-drive bracket.
Agregar Comentario
Free Shipping on all orders USD79.00 and up.
Visita Nuestra Tienda
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Lift the hard-drive off the hard-drive bracket.
  • Lift the hard-drive off the hard-drive bracket.
Agregar Comentario
Remove the interposer from the hard drive.
  • Remove the interposer from the hard drive.
Agregar Comentario
Connect the interposer to the NEW hard drive.
  • Connect the interposer to the NEW hard drive.
Agregar Comentario
Place the hard drive in the hard-drive bracket. Place the hard drive in the hard-drive bracket.
  • Place the hard drive in the hard-drive bracket.
Agregar Comentario
Replace the four screws that secure the hard drive to the hard-drive  bracket.
  • Replace the four screws that secure the hard drive to the hard-drive bracket.
Agregar Comentario
Align the connector on the hard drive with the connector on the system  board and press the hard drive until it is fully seated.
  • Align the connector on the hard drive with the connector on the system board and press the hard drive until it is fully seated.
Agregar Comentario
Tighten the three captive screws that secure the hard-drive assembly to the  computer base.
  • Tighten the three captive screws that secure the hard-drive assembly to the computer base.
Agregar Comentario
Conclusión
Teren Wallace
Miembro Desde 18/12/17
14,715 Reputación
227 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
639 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 10
Todo El Tiempo: 10
