Introducción
In this guide, we will show you how to remove and replace the Display Assembly.
WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Disconnect the antenna cables from the Mini-Card(s).
Agregar Comentario
Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
  • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
Agregar Comentario
Turn the computer over and open the display as far as possible.
  • Turn the computer over and open the display as far as possible.
Agregar Comentario
Pull the pull-tab to disconnect the display cable from the connector on the system board.
  • Pull the pull-tab to disconnect the display cable from the connector on the system board.
Agregar Comentario
Remove the four screws that secure the display assembly to the computer base.
  • Remove the four screws that secure the display assembly to the computer base.
Agregar Comentario
Gently slide the Mini-Card antenna cables out through the slot on the computer base.
  • Gently slide the Mini-Card antenna cables out through the slot on the computer base.
Agregar Comentario
Lift the display assembly off the computer.
  • Lift the display assembly off the computer.
Agregar Comentario
  • Slide the antenna cables in through the slot on the computer base.
Agregar Comentario
Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
Agregar Comentario
Connect the display cable to the connector on the system board.
  • Connect the display cable to the connector on the system board.
Agregar Comentario
Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
  • Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
Agregar Comentario
Connect the Mini-Card antenna cables to the Mini-Card(s).
  • Connect the Mini-Card antenna cables to the Mini-Card(s).
Agregar Comentario
Conclusión
Teren Wallace
Miembro Desde 18/12/17
50,495 Reputación
444 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
921 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 17
