Introducción
In this guide, we will be showing you how to remove and replace the Power-Button Board.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  • Loosen the five captive screws that secure the base cover to the computer base.
Agregar Comentario
Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
Agregar Comentario
Lift the base cover off the computer base.
  • Lift the base cover off the computer base.
Agregar Comentario
Using a plastic scribe, disconnect the battery cable from the system board.
  • Using a plastic scribe, disconnect the battery cable from the system board.
Agregar Comentario
  • Press and hold the power button for five seconds to ground the system board.
Agregar Comentario
  • Connect the battery cable to the system board.
Agregar Comentario
Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
Agregar Comentario
Tighten the five captive screws that secure the base cover to the computer base.
  • Tighten the five captive screws that secure the base cover to the computer base.
Agregar Comentario
  • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
  • Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
Agregar Comentario
Lift the wireless-card bracket off the wireless card.
  • Lift the wireless-card bracket off the wireless card.
Agregar Comentario
Disconnect the antenna cables from the wireless card.
  • Disconnect the antenna cables from the wireless card.
Agregar Comentario
  • Align the notch on the wireless card with the tab on the wireless-card slot.
Agregar Comentario
  • Slide the NEW wireless card at an angle into the wireless-card slot.
Agregar Comentario
  • Connect the antenna cables to the wireless card.
Agregar Comentario
Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
  • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
Agregar Comentario
Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
  • Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
Agregar Comentario
  • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Agregar Comentario
Slide and remove the memory module from the memory-module slot.
  • Slide and remove the memory module from the memory-module slot.
Agregar Comentario
  • Align the notch on the NEW memory module with the tab on the memory-module slot and slide the memory module firmly into the slot at an angle.
Agregar Comentario
Press the memory module down until it clicks into place.
  • Press the memory module down until it clicks into place.
Agregar Comentario
  • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
Agregar Comentario
Lift and slide the solid-state drive from the solid-state drive slot.
  • Lift and slide the solid-state drive from the solid-state drive slot.
Agregar Comentario
  • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
Agregar Comentario
Agregar Comentario
Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
Agregar Comentario
Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
  • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
Agregar Comentario
  • Slide and remove the rear-I/O cover from the computer base.
Agregar Comentario
Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
  • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
Agregar Comentario
  • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
Agregar Comentario
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
  • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Agregar Comentario
Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
  • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
Agregar Comentario
Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Agregar Comentario
Lift the computer base from the palm-rest assembly.
  • Lift the computer base from the palm-rest assembly.
Agregar Comentario
Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
  • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
Agregar Comentario
  • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Agregar Comentario
  • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
Agregar Comentario
  • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Agregar Comentario
  • CAUTION: Removing the coin-cell battery resets the BIOS setup program’s settings to default. It is recommended that you note the BIOS setup program’s settings before removing the coin-cell battery.
  • Disconnect the coin-cell battery cable from the system board.
Agregar Comentario
Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
  • Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
Agregar Comentario
Adhere the NEW coin-cell battery to the palm-rest assembly.
  • Adhere the NEW coin-cell battery to the palm-rest assembly.
Agregar Comentario
  • Connect the coin-cell battery cable to the system board.
Agregar Comentario
  • WARNING: The heat sink may become hot during normal operation. Allow sufficient time for the heat sink to cool before you touch it.
  • CAUTION: For maximum cooling of the processor, do not touch the heat transfer areas on the heat sink. The oils in your skin can reduce the heat transfer capability of the thermal grease.
  • Disconnect the left-fan cable from the system board.
Agregar Comentario
Disconnect the right-fan cable from the system board.
  • Disconnect the right-fan cable from the system board.
Agregar Comentario
In sequential order (as indicated on the heat-sink assembly), remove the seven screws (M2x3) that secure the heat-sink assembly to the system board.
  • In sequential order (as indicated on the heat-sink assembly), remove the seven screws (M2x3) that secure the heat-sink assembly to the system board.
Agregar Comentario
  • Lift the heat-sink assembly off the system board.
Agregar Comentario
CAUTION: Incorrect alignment of the heat sink can damage the system board and processor.
  • CAUTION: Incorrect alignment of the heat sink can damage the system board and processor.
  • NOTE: The original thermal grease can be reused if the original system board and fan are reinstalled together. If either the system board or the fan is replaced, use the thermal pad provided in the kit to ensure that thermal conductivity is achieved.
  • Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
Agregar Comentario
  • In sequential order (indicated on the heat-sink assembly), replace the seven screws (M2x3) that secure the heat-sink assembly to the system board.
Agregar Comentario
  • Connect the right-fan cable to the respective connector on the system board.
Agregar Comentario
  • Connect the left-fan cable to the respective connector on the system board.
Agregar Comentario
Agregar Comentario
Lift the battery off the palm-rest assembly.
  • Lift the battery off the palm-rest assembly.
Agregar Comentario
CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the battery.
  • CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the battery.
  • Using the alignment post, place the NEW battery on the palm-rest assembly.
Agregar Comentario
Adhere the keyboard connector that secures the battery to the palm-rest assembly.
  • Adhere the keyboard connector that secures the battery to the palm-rest assembly.
Agregar Comentario
  • NOTE: Your computer’s Service Tag is stored in the system board. You must enter the Service Tag in the BIOS setup program after you replace the system board.
  • NOTE: Replacing the system board removes any changes you have made to the BIOS using the BIOS setup program. You must make the appropriate changes again after you replace the system board.
  • NOTE: Before disconnecting the cables from the system board, note the location of the connectors so that you can reconnect the cables correctly after you replace the system board.
  • CAUTION: Place the computer on a clean, flat surface.
  • Turn the computer over.
Agregar Comentario
Disconnect the logo-board cable from the system board.
  • Disconnect the logo-board cable from the system board.
Agregar Comentario
Using the pull-tab, disconnect the power-button board cable from the system  board.
  • Using the pull-tab, disconnect the power-button board cable from the system board.
Agregar Comentario
Open the latch and disconnect the display cable from the system board.
  • Open the latch and disconnect the display cable from the system board.
Agregar Comentario
Agregar Comentario
Remove the screw (M2.5x6L) that secures the USB Type-C port bracket to  the system board and lift the USB Type-C port bracket off the system board.
  • Remove the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board and lift the USB Type-C port bracket off the system board.
Agregar Comentario
  • Disconnect the power-adapter port cable from the system board.
Agregar Comentario
Disconnect the speaker cable from the system board.
  • Disconnect the speaker cable from the system board.
Agregar Comentario
Open the latch and disconnect the keyboard cable from the system board.
  • Open the latch and disconnect the keyboard cable from the system board.
Agregar Comentario
Open the latch and disconnect the keyboard-backlight cable from the system  board.
  • Open the latch and disconnect the keyboard-backlight cable from the system board.
Agregar Comentario
Open the latch and disconnect the touch-pad cable from the system board.
  • Open the latch and disconnect the touch-pad cable from the system board.
Agregar Comentario
Agregar Comentario
Remove the two screws (M2.5x6L) that secure the system board to the palm- rest assembly.
  • Remove the two screws (M2.5x6L) that secure the system board to the palm- rest assembly.
Agregar Comentario
Lift the system board off the palm-rest assembly.
  • Lift the system board off the palm-rest assembly.
Agregar Comentario
CAUTION: Ensure that no cables are under the system board.
  • CAUTION: Ensure that no cables are under the system board.
  • Align the screw holes on the NEW system board with the screw holes on the palm- rest assembly.
Agregar Comentario
Replace the two screws (M2.5x6L) that secure the system-board to the palm- rest assembly.
  • Replace the two screws (M2.5x6L) that secure the system-board to the palm- rest assembly.
Agregar Comentario
Align the screw hole on the USB Type-C port bracket with the screw hole on  the system board on the back and right side of your computer.
  • Align the screw hole on the USB Type-C port bracket with the screw hole on the system board on the back and right side of your computer.
Agregar Comentario
Replace the screw (M2.5x6L) that secures the USB Type-C port bracket to  the system board on the back and right side of your computer.
  • Replace the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board on the back and right side of your computer.
Agregar Comentario
  • Slide the touch-pad cable into the connector on the system board and close the latch to secure the cable.
Agregar Comentario
Slide the keyboard-backlight cable into the connector on the system board  and close the latch to secure the cable.
  • Slide the keyboard-backlight cable into the connector on the system board and close the latch to secure the cable.
Agregar Comentario
Slide the keyboard cable into the connector on the system board and close  the latch to secure the cable.
  • Slide the keyboard cable into the connector on the system board and close the latch to secure the cable.
Agregar Comentario
  • Connect the speaker cable to the system board.
Agregar Comentario
  • Connect the power-adapter port cable to the system board.
Agregar Comentario
Agregar Comentario
  • Slide the display cable into the connector on the system board and close the latch to secure the cable.
Agregar Comentario
  • Connect the power-button board cable to the system board.
Agregar Comentario
  • Connect the logo-board cable to the system board.
Agregar Comentario
  • Remove the two screws (M2x3) that secure the power-button board to the palm-rest assembly.
Agregar Comentario
Lift the power-button board, along with its cable, off the palm-rest assembly.
  • Lift the power-button board, along with its cable, off the palm-rest assembly.
Agregar Comentario
Peel the power-button board cable from the palm-rest assembly.
  • Peel the power-button board cable from the palm-rest assembly.
Agregar Comentario
Using the alignment posts, place the NEW power-button board on the palm-rest  assembly.
  • Using the alignment posts, place the NEW power-button board on the palm-rest assembly.
Agregar Comentario
Adhere the power-button board cable to the palm-rest assembly.
  • Adhere the power-button board cable to the palm-rest assembly.
Agregar Comentario
Align the screw holes on the power-button board with the screw holes on the  palm-rest assembly.
  • Align the screw holes on the power-button board with the screw holes on the palm-rest assembly.
Agregar Comentario
Replace the two screws (M2x3) that secure the power-button board to the  palm-rest assembly.
  • Replace the two screws (M2x3) that secure the power-button board to the palm-rest assembly.
Agregar Comentario
Conclusión
Teren Wallace
Miembro Desde 18/12/17
14,715 Reputación
227 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
639 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 5
