Saltar al contenido principal
Dell Inspiron 15-7569 Battery Replacement
Qué necesitas
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: paso 1, imagen 1 de 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: paso 1, imagen 2 de 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: paso 2, imagen 1 de 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: paso 2, imagen 2 de 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: paso 2, imagen 3 de 3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team S5-G4, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
4 Miembros
6 Guías creadas
Un comentario
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 34
Todo El Tiempo: 6,196
