Saltar al contenido principal
DJI Phantom 4 Advanced Remote Controller Back Panel Replacement
Qué necesitas
  1. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: paso 2, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: paso 2, imagen 2 de 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: paso 3, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: paso 3, imagen 2 de 2
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: paso 4, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: paso 4, imagen 2 de 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: paso 5, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: paso 5, imagen 2 de 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 755
