Saltar al contenido principal
DBPOWER T20 Disassembly
Qué necesitas
  1. DBPOWER T20 Disassembly, DBPOWER T20 Disassembly: paso 1, imagen 1 de 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Disassembly: paso 2, imagen 1 de 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Disassembly: paso 3, imagen 1 de 3 DBPOWER T20 Disassembly: paso 3, imagen 2 de 3 DBPOWER T20 Disassembly: paso 3, imagen 3 de 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Disassembly: paso 4, imagen 1 de 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Disassembly: paso 5, imagen 1 de 2 DBPOWER T20 Disassembly: paso 5, imagen 2 de 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Disassembly: paso 6, imagen 1 de 3 DBPOWER T20 Disassembly: paso 6, imagen 2 de 3 DBPOWER T20 Disassembly: paso 6, imagen 3 de 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Disassembly: paso 7, imagen 1 de 2 DBPOWER T20 Disassembly: paso 7, imagen 2 de 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Disassembly: paso 8, imagen 1 de 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Disassembly: paso 9, imagen 1 de 2 DBPOWER T20 Disassembly: paso 9, imagen 2 de 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Disassembly: paso 10, imagen 1 de 2 DBPOWER T20 Disassembly: paso 10, imagen 2 de 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
Conclusión
Una persona más ha completado esta guía.
Andrea Espinosa
Miembro Desde 02/15/18
506 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S16-G2, Boczar Spring 2018 Miembro de USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Miembros
5 Guías creadas
4 comentarios
Anyone find a bulb for this thing? And/or know what else (or a quick fix) would fix a dark or burn mark on the image?
jcr4130 - Contestar
haing the same issue tried to call a electronics repair place to see if the could order a new polarizing lens for me and they said they could not unless they were the ones that did the repair
derek_russell82308 -
Really? Well, crap
KweenBeeTX -
How are the lenses supposed to sit in the hompow t20 mini projector
Joseph Duffey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 2,816
