Partes
No se requieren partes.
Using your thumb, slide down and remove the battery cover.
  • Using your thumb, slide down and remove the battery cover.
Agregar Comentario
Using your index finger, remove the old AA battery.
  • Using your index finger, remove the old AA battery.
  • Install the new AA battery.
Agregar Comentario
Slide down the eject button.
  • Slide down the eject button.
  • Pull out the old SmartMedia Card.
  • Insert the new SmartMedia Card.
    • The notched corner of the SmartMedia card should go in the top left corner.
Agregar Comentario
Using a Phillips #00 Screwdriver, remove the two 7.5mm screws from the sides of the back cover.
  • Using a Phillips #00 Screwdriver, remove the two 7.5mm screws from the sides of the back cover.
Agregar Comentario
Lift the back cover off of the NOMAD II.
  • Lift the back cover off of the NOMAD II.
  • Remove the rubber USB port cover, the connected buttons along the left edge, and the plastic lock/unlock button on the upper right edge of the device.
Agregar Comentario
Using a Phillips #00 Screwdriver, remove the two 5.5mm screws from the sides of the battery compartment.
  • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws from the sides of the battery compartment.
Agregar Comentario
Carefully remove the battery compartment.
  • Carefully remove the battery compartment.
Agregar Comentario
Using a Phillips #00 Screwdriver, remove the two 5.5mm screws on the left and right edges of the circuit board.
  • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws on the left and right edges of the circuit board.
Agregar Comentario
Using a pair of tweezers, carefully pry the metal loop on the left side of the battery compartment away from the case.
  • Using a pair of tweezers, carefully pry the metal loop on the left side of the battery compartment away from the case.
Agregar Comentario
Pull the circuit boards out of the back cover.
  • Pull the circuit boards out of the back cover.
    • During reinstallation, firmly press the top of the circuit boards into the cover until you hear a click.
Agregar Comentario
Gently pry the circuit boards apart.
  • Gently pry the circuit boards apart.
    • This must be done with the USB port facing up, as shown.
Agregar Comentario
Desolder the seven solder joints which hold the lock switch in place.
  • Desolder the seven solder joints which hold the lock switch in place.
  • Install the new lock/unlock switch.
Agregar Comentario
Conclusión
Craig Fischer
Miembro Desde 24/01/12
21 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-2, Regan Winter 2012 Miembro de Cal Poly, Team 9-2, Regan Winter 2012
CPSU-REGAN-W12S9G2
5 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,682
