Introducción
How to remove the Compaq Evo 1000v keyboard.
Partes
No se requieren partes.
Turn the laptop bottom side up with the rear panel facing forward.
  • Turn the laptop bottom side up with the rear panel facing forward.
Agregar Comentario
Remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  • Remove the two T8 Torx screws that secure the LED cover to the base enclosure.
Agregar Comentario
Turn the laptop top side up with the front facing forward. Open the screen.
  • Turn the laptop top side up with the front facing forward. Open the screen.
Agregar Comentario
Locate the F1 and F2 keys near the top left corner of the keyboard.
  • Locate the F1 and F2 keys near the top left corner of the keyboard.
Agregar Comentario
While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
Agregar Comentario
Locate the Pause and Scroll keys near the top right corner of the keyboard.
  • Locate the Pause and Scroll keys near the top right corner of the keyboard.
Agregar Comentario
While holding the Pause and Scroll keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  • While holding the Pause and Scroll keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
Agregar Comentario
Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover. Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
Agregar Comentario
Lift the back edge of the keyboard and pull towards the screen.
  • Lift the back edge of the keyboard and pull towards the screen.
Agregar Comentario
Pull the cable and lift up to release.
  • Pull the cable and lift up to release.
Agregar Comentario
Remove the keyboard.
  • Remove the keyboard.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
kim
Miembro Desde 14/04/10
47 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 29-74, Johann Spring 2010 Miembro de Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 3,410
