Press the eject button to view the laser inside. Using the blue plastic tool and the tweezers, remove the ribbon cable. Using the blue plastic tool and the tweezers, remove the ribbon cable.
  • Press the eject button to view the laser inside.
  • Using the blue plastic tool and the tweezers, remove the ribbon cable.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver. Do not lift the top of the DVD player too quickly because there are wires attached on the inside. Pry the top of the device open from the right side where the buttons are located.
  • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
  • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
  • Pry the top of the device open from the right side where the buttons are located.
Agregar Comentario
When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
  • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
Agregar Comentario
Conclusión
Kyle VanAllen
Miembro Desde 20/01/12
70 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-36, Amido Winter 2012 Miembro de Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 208
