Cirago M9030 IDE Connector Replacement
  1. Cirago M9030 IDE Connector Replacement, Cover: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 IDE Connector Replacement: step 2, image 1 of 1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 IDE Connector Replacement: step 3, image 1 of 2 Cirago M9030 IDE Connector Replacement: step 3, image 2 of 2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 IDE Connector Replacement, Hard Drive: step 4, image 1 of 1
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 IDE Connector Replacement: step 5, image 1 of 3 Cirago M9030 IDE Connector Replacement: step 5, image 2 of 3 Cirago M9030 IDE Connector Replacement: step 5, image 3 of 3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 IDE Connector Replacement: step 6, image 1 of 3 Cirago M9030 IDE Connector Replacement: step 6, image 2 of 3 Cirago M9030 IDE Connector Replacement: step 6, image 3 of 3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
  7. Cirago M9030 IDE Connector Replacement, IDE Connector: step 7, image 1 of 2 Cirago M9030 IDE Connector Replacement, IDE Connector: step 7, image 2 of 2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
  8. Cirago M9030 IDE Connector Replacement: step 8, image 1 of 1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  9. Cirago M9030 IDE Connector Replacement: step 9, image 1 of 2 Cirago M9030 IDE Connector Replacement: step 9, image 2 of 2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  10. Cirago M9030 IDE Connector Replacement: step 10, image 1 of 1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  11. Cirago M9030 IDE Connector Replacement: step 11, image 1 of 2 Cirago M9030 IDE Connector Replacement: step 11, image 2 of 2
    • Completely remove the IDE connector from the device.
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
Ryan Sutardji
171 Reputation
7 Guides authored
Cal Poly, Team 1-4, Regan SU 2012 Member of Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 964
