Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the top side.
  • Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the top side.
Agregar Comentario
Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the bottom side.
  • Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the bottom side.
  • Remove the warranty sticker across the bottom.
Agregar Comentario
Gently lift off the back and front casing. The outer shell should easily come apart.
  • Gently lift off the back and front casing.
  • The outer shell should easily come apart.
Agregar Comentario
Make sure the device screen is face down.
  • Make sure the device screen is face down.
Agregar Comentario
Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive. Raise the bottom edge of the hard drive 15 degrees up from the device. Raise the bottom edge of the hard drive 15 degrees up from the device.
  • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
  • Raise the bottom edge of the hard drive 15 degrees up from the device.
Agregar Comentario
Place fingers on the IDE connectors and  gently slide the hard drive out from the   IDE module. Place fingers on the IDE connectors and  gently slide the hard drive out from the   IDE module. Place fingers on the IDE connectors and  gently slide the hard drive out from the   IDE module.
  • Place fingers on the IDE connectors and gently slide the hard drive out from the IDE module.
Agregar Comentario
Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard. Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard.
  • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard.
Agregar Comentario
Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
Agregar Comentario
Using the plastic opening tool, completely lift the metal bracket off of the motherboard. Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
  • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
Agregar Comentario
Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
Agregar Comentario
Completely remove the IDE connector from the device. The audio jack is attached to the IDE connector.  Pull at a 45 degree angle from the audio jack.
  • Completely remove the IDE connector from the device.
  • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
Agregar Comentario
Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard. Completely remove the motherboard.
  • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
  • Completely remove the motherboard.
  • The motherboard should slide out easily.
Agregar Comentario
Set aside the front cover.
  • Set aside the front cover.
  • Flip over the motherboard.
  • Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
Agregar Comentario
Using the tweezers, lift up the button module to a 180 degree angle. Leave the button module attached by the ribbon. Flip over the motherboard with the button module still attached.
  • Using the tweezers, lift up the button module to a 180 degree angle.
  • Leave the button module attached by the ribbon.
  • Flip over the motherboard with the button module still attached.
Agregar Comentario
Fold the button module over the motherboard. Using the tweezers, remove the ribbon pin. The ribbon pin should snap completely off of the motherboard.
  • Fold the button module over the motherboard.
  • Using the tweezers, remove the ribbon pin.
  • The ribbon pin should snap completely off of the motherboard.
Agregar Comentario
The ribbon should easily detach from the motherboard. The ribbon should easily detach from the motherboard.
  • The ribbon should easily detach from the motherboard.
Agregar Comentario
Conclusión
Ryan Sutardji
Miembro Desde 29/06/12
171 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 1-4, Regan SU 2012 Miembro de Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 869
