Partes
No se requieren partes.
  • Hold the phone with the back (camera side) facing you. Slide the battery cover off of the phone.
Agregar Comentario
  • Pull the battery out by lifting the black tab on the left side of the battery.
Agregar Comentario
  • Remove the camera cover of the phone, using your light blue wedge tool.
Agregar Comentario
  • Unscrew the four black Torx head screws, found in each corner of the back.
  • Warning: Unscrewing the screw indicated in the picture will void any warranty on the phone.
Agregar Comentario
Unscrew the black Phillips head screw below the right speaker.
  • Unscrew the black Phillips head screw below the right speaker.
Agregar Comentario
  • After removing the screw, pull up on the motherboard to release it from the circuit board (green tab, see Figure 11). This will simply snap out, and does not require too much force.
Agregar Comentario
Remove the keyboard by unscrewing the two pairs of silver Torx head screws that run along the sliding tracks.
  • Remove the keyboard by unscrewing the two pairs of silver Torx head screws that run along the sliding tracks.
Agregar Comentario
Remove the four silver Phillips head screws from the screened half of the phone.
  • Remove the four silver Phillips head screws from the screened half of the phone.
Agregar Comentario
Use the light blue wedge tool to remove the back. The circuit board will slide out of the slot and will stay attached to the remaining front half of the phone.
  • Use the light blue wedge tool to remove the back. The circuit board will slide out of the slot and will stay attached to the remaining front half of the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Unscrew the four Phillips head screws that attach the screen to the front case.
  • Unscrew the four Phillips head screws that attach the screen to the front case.
Agregar Comentario
  • Remove the circuit board; pull it apart at the orange tab. This will detach the screen from its circuit board.
Agregar Comentario
Attach the new screen by aligning the orange tab with the beige rectangle on the circuit. Secure by pushing down on the bronze piece.
  • Attach the new screen by aligning the orange tab with the beige rectangle on the circuit. Secure by pushing down on the bronze piece.
Agregar Comentario
  • Place screen back into front cover.
Agregar Comentario
  • Screw the four smallest silver Torx head screws into the circuit board, which will attach it to the front cover.
Agregar Comentario
  • Feed the circuit board through the back piece.
Agregar Comentario
  • Use the four Phillips head silver screws to attach the back piece to the front of the phone.
Agregar Comentario
Slide the circuit board through the slot in the keyboard.
  • Slide the circuit board through the slot in the keyboard.
Agregar Comentario
  • Attach the keyboard to the sliding tracks using the four silver Torx screws.
Agregar Comentario
Attach the motherboard to the circuit board, aligning the two white rectangles until they snap into place. Lay motherboard into place.
  • Attach the motherboard to the circuit board, aligning the two white rectangles until they snap into place. Lay motherboard into place.
Agregar Comentario
Secure the motherboard by screwing the small black Phillips head screw into place, located below the right speaker. Note: You may need to remove the right speaker in order to replace this screw.
  • Secure the motherboard by screwing the small black Phillips head screw into place, located below the right speaker. Note: You may need to remove the right speaker in order to replace this screw.
Agregar Comentario
  • Place the back cover onto the motherboard, clicking it into place.
Agregar Comentario
Secure the back cover by screwing the four long, black Torx screws into the four corners of the back cover.
  • Secure the back cover by screwing the four long, black Torx screws into the four corners of the back cover.
Agregar Comentario
Replace the camera cover.
  • Replace the camera cover.
Agregar Comentario
Replace battery, keeping the black tab available to grab.
  • Replace battery, keeping the black tab available to grab.
Agregar Comentario
Slide the battery cover back into place.
  • Slide the battery cover back into place.
Agregar Comentario
Conclusión
Laura Kimberly Simonds
Miembro Desde 24/09/12
301 Reputación
3 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 351
