Saltar al contenido principal
Casio Exilim EX-Z850 Flash Assembly Replacement
Qué necesitas
  1. Casio Exilim EX-Z850 Flash Assembly Replacement, Flash Assembly: paso 1, imagen 1 de 1
    • With your Phillips #00 screwdriver, remove the four screws on the side of the camera.
  2. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 2, imagen 1 de 1
    • With a Phillips #00 screwdriver, remove the four screws located on the bottom of the camera.
    • The bottom screws are longer than the top screws, so label accordingly for easy reassembly.
  3. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 3, imagen 1 de 1
    • With a Phillips #00 screwdriver, remove the four screws on the opposite side of the camera.
  4. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 4, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 4, imagen 2 de 2
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove the ribbon from the LCD screen.
    • Set bottom casing aside.
    • Prying open the camera from the casing could potentially damage the device, so open the casing slowly.
  5. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 5, imagen 1 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 5, imagen 2 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 5, imagen 3 de 3
    • Using tweezers, gently pry apart the top casing from the camera.
    • Set the top casing aside.
  6. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 6, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 6, imagen 2 de 2
    • Use tweezers to pry the LCD screen off from the opening.
    • The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
  7. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 7, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 7, imagen 2 de 2
    • Use tweezers to lift up the LCD screen away from the camera.
    • Moving the screen could potentially damage the wire connecting it to the camera, so move the LCD screen slowly.
  8. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 8, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 8, imagen 2 de 2
    • Use tweezers to slowly pry off LCD casing by lifting and moving it off the camera.
  9. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 9, imagen 1 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 9, imagen 2 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 9, imagen 3 de 3
    • Use tweezers to flip open the connector holding the ribbon.
    • Gently pull out the LCD screen with the ribbon from the camera.
  10. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 10, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 10, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
  11. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 11, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 11, imagen 2 de 2
    • On the front of the camera, detach the ribbon from the connector.
  12. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 12, imagen 1 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 12, imagen 2 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 12, imagen 3 de 3
    • Carefully remove the L shaped frame from the camera.
    • There is a yellow and orange wire connected to camera. Be careful not to pull them off.
    • At the bottom of the camera, the L-shaped frame is connected by two plastic bumps and a metal tab.
  13. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 13, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the two screws on the front of the flash assembly.
    • Remove flash assembly, and replace it with a new flash assembly.
Conclusión
Una persona más ha completado esta guía.
Christian
Miembro Desde 01/28/11
320 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-38, Regan Winter 2011 Miembro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 2,791
