Saltar al contenido principal
Casio Exilim EX-Z850 Battery Casing Disassembly
Qué necesitas
  1. Casio Exilim EX-Z850 Battery Casing Disassembly, Casio Exilim EX-Z850 Battery Casing Disassembly: paso 1, imagen 1 de 1
    • Remove battery before you begin disassembly.
    • Use a Phillips #00 Screwdriver to remove all four of the screws on the right side of the camera with the lens facing you.
  2. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver, unscrew all four screws on the left side of the camera.
  3. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 3, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove all four of the screws on the bottom of the camera.
    • Bottom screws are longer than the top screws, so label accordingly for easy reassembly.
  4. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 4, imagen 1 de 3 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 4, imagen 2 de 3 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 4, imagen 3 de 3
    • Once all screws have been removed, slowly pry open the back casing of the camera.
    • Gently remove the ribbon cable from the LCD with tweezers.
    • Set aside back casing of the camera.
  5. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 5, imagen 1 de 2 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 5, imagen 2 de 2
    • Use your tweezers to hold the camera secure, while you pull the front cover off of the camera.
  6. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 6, imagen 1 de 2 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 6, imagen 2 de 2
    • The bottom of the LCD screen is secured to the frame by small pieces of black tape. You will need to peel the tape away to release the LCD screen.
    • Use your tweezers to lift the LCD screen from the frame.
  7. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 7, imagen 1 de 2 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 7, imagen 2 de 2
    • Lift screen away from the camera with your tweezers.
    • Flip screen over gently with your fingers once it is lifted far away enough from the camera.
  8. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 8, imagen 1 de 1
    • Use your tweezers to lift the LCD frame from the camera.
  9. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 9, imagen 1 de 3 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 9, imagen 2 de 3 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 9, imagen 3 de 3
    • Use your tweezers to lift the bar holding the ribbon off.
    • Disconnect the ribbon to release the LCD screen.
    • Use your fingers to pull the LCD screen with the attached ribbon from the camera.
  10. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 10, imagen 1 de 2 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 10, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two screws from the side of the camera that has the strap mount.
    • Remove strap mount by slowly pulling the side of the case so it will dislocate from the top of the camera.
  11. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 11, imagen 1 de 2 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 11, imagen 2 de 2
    • Hold the camera facing toward you. Pull up the bar that is securing the ribbon located to the left of the flash.
    • Disconnect the ribbon by prying it off with your fingers.
  12. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 12, imagen 1 de 3 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 12, imagen 2 de 3 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 12, imagen 3 de 3
    • With the lens facing towards you, pull the L-shaped frame away from the camera.
    • Do not disconnect any of the wires from the camera when pulling the frame.
    • Remove the frame from the two studs and metal tabs keeping it in place at the bottom of the camera.
  13. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 13, imagen 1 de 2 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 13, imagen 2 de 2
    • Locate the logic board to the left of the lens. You will see a bar securing a ribbon. Flip the bar up to release the ribbon.
    • Disconnect the ribbon.
  14. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 14, imagen 1 de 2 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 14, imagen 2 de 2
    • Use your Phillips #00 screwdriver to remove the two screws connecting the frame to the back of the camera.
    • Lift the frame away on the LCD screen side of the camera.
  15. Casio Exilim EX-Z850 Battery Casing Disassembly: paso 15, imagen 1 de 2 Casio Exilim EX-Z850 Battery Casing Disassembly: paso 15, imagen 2 de 2
    • This is what your camera should look like now that you have the battery casing isolated.
Conclusión
Logan
Miembro Desde 01/10/11
313 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-38, Regan Winter 2011 Miembro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 3,800
