Partes
No se requieren partes.
Use a pair of tweezers to gently move the wire away from the lens This will make the area around the lens easily accessible
  • Use a pair of tweezers to gently move the wire away from the lens
  • This will make the area around the lens easily accessible
Agregar Comentario
The lens is held in by two hooks, one in the upper left hand corner and another in the lower right Using a screwdriver push the metal hooks on the upper left corner, underneath the edge of circuit board. Pull up on the upper left corner of the lens, freeing the corner from the camera casing.
  • The lens is held in by two hooks, one in the upper left hand corner and another in the lower right
  • Using a screwdriver push the metal hooks on the upper left corner, underneath the edge of circuit board. Pull up on the upper left corner of the lens, freeing the corner from the camera casing.
Agregar Comentario
While pulling the lens up out of the casing, push the hook to the lower right corner of the lens out of the way. At this point the lens should be connected to the camera solely by two orange plastic strips.
  • While pulling the lens up out of the casing, push the hook to the lower right corner of the lens out of the way.
  • At this point the lens should be connected to the camera solely by two orange plastic strips.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using tweezers or finger nails pull up the brown flaps where the two orange film strips connected to the lens meets the circuit board. Use tweezers to pull the orange film strips out of the port. It should come out easily. There are two additional film strips connected to the circuit board that do not need to be removed. These are connected to the opposite side of the circuit board than the lens.
  • Using tweezers or finger nails pull up the brown flaps where the two orange film strips connected to the lens meets the circuit board.
  • Use tweezers to pull the orange film strips out of the port. It should come out easily.
  • There are two additional film strips connected to the circuit board that do not need to be removed. These are connected to the opposite side of the circuit board than the lens.
Agregar Comentario
  • Completely remove the lens. There should not be anything else holding it in place.
Agregar Comentario
Turn the lens over On the back are four screws. Remove the two silver screws (4.36 mm) from the back of the lens.
  • Turn the lens over
  • On the back are four screws. Remove the two silver screws (4.36 mm) from the back of the lens.
Agregar Comentario
Remove the loose piece from the back of the lens and set it aside
  • Remove the loose piece from the back of the lens and set it aside
  • The lens is now ready to be replaced with a new one.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Dylan Fuller
Miembro Desde 12/04/12
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 17-28, Amido Spring 2012 Miembro de Cal Poly, Team 17-28, Amido Spring 2012
CPSU-AMIDO-S12S17G28
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 577
