Partes
No se requieren partes.
Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom.
  • Locate 12 screws. Four on the left, four on the right, and four on the bottom.
Agregar Comentario
Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
  • Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
Agregar Comentario
Separate the front case from the body of the camera.
  • Separate the front case from the body of the camera.
Agregar Comentario
Separate the back case from the body of the camera.
  • Separate the back case from the body of the camera.
Agregar Comentario
Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up. Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up. Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
  • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
  • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
Agregar Comentario
Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
Agregar Comentario
Continue to lift the LCD screen all the way up. Be careful not to rip any wires connecting the LCD screen to the top of the camera.
  • Continue to lift the LCD screen all the way up.
  • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
Agregar Comentario
Remove the orange strip by grabbing the white tab and pulling. Remove the orange strip by grabbing the white tab and pulling.
  • Remove the orange strip by grabbing the white tab and pulling.
Agregar Comentario
Remove the two 1.68mm screws located on the motherboard, using a #00 Phillips screwdriver.
  • Remove the two 1.68mm screws located on the motherboard, using a #00 Phillips screwdriver.
Agregar Comentario
Using the plastic opening tool, pry the battery case clamps (located on front of the camera) so that the bottom will come loose.
  • Using the plastic opening tool, pry the battery case clamps (located on front of the camera) so that the bottom will come loose.
Agregar Comentario
Detach the inner orange strip from the motherboard to the lens by inserting the plastic opening tool under the tab and llifting up.
  • Detach the inner orange strip from the motherboard to the lens by inserting the plastic opening tool under the tab and llifting up.
Agregar Comentario
Fully remove the motherboard from the lens.
  • Fully remove the motherboard from the lens.
  • It will be still be attached by wires and a different orange strip.
there is no cautionary notes about being extra careful to not touch certain parts...?
cagineer - Contestar
Conclusión
Una persona más ha completado esta guía.
Taylor
Miembro Desde 18/04/12
31 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 9-45, Regan Spring 2012 Miembro de Cal Poly, Team 9-45, Regan Spring 2012
CPSU-REGAN-S12S9G45
7 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 571
